The most common cause of a rough idle is an engine vacuum leak, is that something that has been checked? Also, is the check engine light staying on when the engine is running? If it is, have you had the computer scanned for diagnostic trouble codes? I ask because although a vacuum leak is very common, there are other things that can do it as well. For example, a fuel pressure issue, dirty throttle body, air/fuel mixture issue, and so on.
Let's start by checking if there is a vacuum leak.
Here is a link that explains how it's done:
Also, if the check engine light is staying on, have the computer scanned for codes. Most parts stores will do it for you free of charge.
Aug 15, 2022 at 10:39 PM
