Rough idle low power
2000 CHEVROLET S-10
150,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DWALDEN71
About a month ago I went through the car wash and my truck starting running rough after an hour or so it was fine. Then yesterday I went through a creek over a road and it started the rough idle and low power and never quit. I replaced the plugs plug wires and both coil packs still running rough with no power.
Jul 23, 2020 at 4:58 PM
There are a few different ignition components that could have gotten wet. If you haven't already, the computer should be scanned to see where the problem is coming from. Here is a quick video showing how it's done:
https://youtu.be/b2IJGfImVvw
I realize most people don't own a scan tool, but most parts stores will do it free of charge or lend/rent the scan tool to you.
If you haven't done it, start with this. If you have, let me know what codes were retrieved.
Jul 23, 2020 at 9:07 PM
DWALDEN71
Took the truck had it scanned there was no codes except p1670 and it had something to do with the transmission.
Jul 25, 2020 at 9:48 AM
The only other thing I can think of then is if the engine took on water which caused something to happen directly to the engine. You may want to do a compression test to confirm that all cylinders are within spec. If it was something electronic, it would have shown up with the scan.
Jul 25, 2020 at 10:05 PM
