I recently bought my 04 Mustang GT. I knew it had some issues with idle and not driving very smooth. I did replace spark plugs, coils, Pcv valve, fuel filter. It does have a cold air intake and strait pipes. Original error codes it had was p0132, p2195, p0172 and p02196. Cleared codes did tuneup and then got p0300, p0316 and p2195. Replaced fuel injectors and bank1 upstream o2 sensor trying to p2195. Injectors took care of misfire codes. Still have the p2195 code. Checked my vacuum and it read 16.5 inHg. Right in the “lateing timing” range. 17-22 inHg is “normal engine” range on my guage. I have no idea what Lateing timing means! My short term fuel trim for bank1 ranged from 20-33% at idle and bank2 ranged from -3-9%. Any help you can give would be greatly appreciated!
Jul 11, 2025 at 5:45 PM
