My vehicle has been having a very hard time idling. The engine shakes badly when you push on the gas pedal, and often times stalls when you let go of the gas or try to change gears. when the car is able to idle it is very weak, and will usually stall after a few minutes. The exhaust manifold on the drivers side smokes white when started as well. The car backfires a lot, but overall performance improves once the car has been driven for a while. The car preforms better the faster you go, but at stops signs, it sometimes tries to stall out. The car also has a manual choke that I have not mastered very well, and I don't think the carburetor has ever been tuned, so those two things might be contributing to the problems as well. One odd thing, the car started up and idled fairly well in extremely cold temperatures the other day.
Feb 4, 2019 at 12:28 PM
