Rough idle and momentary loss of power
1996 NISSAN HARDBODY
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NISSAN43
The truck loses power or kind of bogs down a small bit but is very noticeable from time to time not constant. It has a rough or erratic idle.
Sep 28, 2017 at 12:41 PM
MHPAUTOS
  • 31,937 POSTS
Sounds as if it is a fuel related problem. i would start with a code scan just to see if there are any set fault code. not all codes will set a check light. also, check fuel pressure and replace the fuel filter if this has not been done for some time. start here.
Sep 28, 2017 at 5:48 PM
