Rough idle and loss of power
1999 MITSUBISHI PAJERO
180,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
BLAINE KEREKU
I just overhauled the engine. Replace new piston rings and oil seals. I started the engine, and it gave me all these problems.
Oct 16, 2021 at 9:43 PM
We don't have a manual on this engine so I can't provide specifics, but we need to find out if these issues in these guides are there because they will cause these issues.
First is a vacuum leak. We need to use this guide to inspect for a vacuum leak to find out if we have a line off or even an intake manifold leak:
Next, we need to find out if you have good compression as you will have low power and rough running if the compression is not correct.
Here is a guide that will help with this:
Lastly if both of these check out then we need to run through this guide that talks about this issue in more general terms:
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Let's start with all this info and we can go from there. Thanks
Oct 17, 2021 at 9:55 AM
