Rough idle
1996 MITSUBISHI 3000GT
206,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
FIRECREW13
First, I have changed plugs, wires and coils tested good. New fuel filter and injectors were removed and cleaned. After inspecting valve train I found a rocker arm off and lying in top of the head. Reinstalled . (bought car two days ago, valve stem top looked good and everything in valve train looked normal) The car has a miss at idle but runs perfect on acceleration and at highway speeds. Any idea what I need to focus on? there is one vacuum line off from the intake to the throttle body but its plugged on both ends. the rocker arm was on the intake valve that cam off. no backfiring to indicate intake valve issue.
Sep 29, 2016 at 5:06 AM
HMAC300
  • 48,601 POSTS
check for a vacuum leak and compression start there then scan for codes if it is a 300 series code 300-06 then it has a misfire and freeze frame it to check sensors.
Sep 29, 2016 at 6:06 AM
