I just recently replaced the IPR valve and ICP sensor and I am getting 2 DTCs P1284 and P1211. It will start up right away and run fine for about 5 seconds then the check engine light pops on and starts to run really rough. And when you touch the gas pedal it will go from about 500 RPMs to over 1,500 instantly even if you slightly touch it. Could there be air in the system still?
Sep 20, 2024 at 6:13 AM
