Have problem with very rough idle. Think I have looked at everything, but still can't find problem.
Compression test: All okay, about 148 psi, +/- 10%
New plugs and wires, think distributor is fine.
Checked every single vacuum hose, I think. Most now new or like new.
Sprayed carburetor cleaner all around carburetor and intake. No change in speed.
Tightened all carburetor and intake manifold bolts.
Adjusted Q-Jet idle screws, does not affect much at all.
When put hand over intake, when running, speed up a little, so maybe running lean, but screwing idle mixture screws out does not help, even if out until about fall out.
Seems to get enough fuel, runs great at high RPM.
Thanks for your help!!
May 21, 2019 at 5:48 AM
