Transmission fluid is low, despite recent flush & refill. Shifting into drive & reverse causes loud "clunk" & a tell-tale jolt that can be felt from the inside indicating rough gear changes. Oil level is full. Coolant a bit low as well. Engine temp. is normal while cruising but jumps up to 1/2 - 3/4 in stop & go driving. Also, I recently had the power steering fluid flushed & refilled. Before the flush I had no problems, but now the axle creaks quite a bit when I turn.
Jul 29, 2013 at 7:15 PM
