Rough engine idling
2015 KIA SORENTO
170,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DAVE0104
Obd code said crankshaft position sensor needed replacement so I did that. The next day (not driven 100 miles yet) the problem of rough idling exists and the “check engine” will flash until I pull over and stop/start the engine. Will the problem resolve itself and the light go out?
May 30, 2019 at 5:45 PM
Hi Dave,
When you say the check engine light is flashing. Do you mean it comes on and stays on then goes out intermittently or it is steadily flashing?
If it is flashing steadily, you don't want to drive it until you pull codes again and fix what most likely will be a misfire. This flashing check engine light means you are doing potential catastrophic damage to the engine and or exhaust because there is a server misfire.
This will also explain the rough idle and running condition.
Please pull the codes and send me what you find and we can go from there. Thanks
https://www.2carpros.com/articles/engine-vibration-at-idle
May 31, 2019 at 7:37 PM
