Front Brake Rotors?
2012 TOYOTA HIGHLANDER
100,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
STRENGER
Front brake rotors have half-moon grooves on both sides that look the same.
Jul 3, 2022 at 7:41 AM
Yes, this is normal, it helps with the cooling of the brakes. Are you having a problem, do you need to know how to change them out with the pads? If so, I have included the instructions for the brakes in the diagram below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jul 3, 2022 at 10:28 AM
SQM
  • 6,383 POSTS
I think you are mentioning the groves that help with cooling.
So that is completely normal.
Let me know if you have any specific concerns.
Thank you.
Jul 3, 2022 at 10:29 AM
STRENGER
Thanks, also when applying brakes I hear a little grind at the end of stopping . maybe need new pads.
Jul 3, 2022 at 12:31 PM
Yes, that is common. here is the part number for the front pads:
Front Pads 044650E010 $104.50.
Rear Pads 044660E020 $67.50.
Let me know if you have problems and I can help.
Jul 3, 2022 at 12:35 PM
STRENGER
thanks for all the help.
Jul 4, 2022 at 12:36 PM
SQM
  • 6,383 POSTS
You are welcome.
Thank you for using 2CarPros.
Jul 5, 2022 at 8:48 AM
