If you are unable to remove the rotor, there aren't too many choices. Did you use a propane torch to heat it or an oxy-acetylene torch? Propane won't get it hot enough.
If it will not come off using a heavy hammer and heat, you will likely need to start cutting until it loosens enough to hammer it off.
I know that sounds crazy, but if you have everything unbolted and it still won't move, that is the only thing I can think of other than replacing the entire spindle assembly/knuckle.
Let me know. Also, if you could upload a pic of what is happening, it may help me.
Apr 25, 2021 at 8:05 PM
