I’m hearing a rotational squeak that does it in synchronization with the wheels spinning, it starts at 15mph and is more audible when I initially start driving the truck in the morning or after my 8 hour shift at work and seems to quiet down when I drive for a while I can barely hear it, it would be audible when I pass by a car or wall where the sound echos. It seems to be coming from the rear, I have replaced both front wheel hub bearings and in the rear I have replaced both u joints 2 years ago, had them checked by a mechanic recently and there is no play or clunking noise, changed the rear differential oil 3 years ago and there was no metal shavings at the time it got done so now I’m stuck between rear wheel bearings or worst case rear differential getting ready to go out? Sound does not change when I brake so I don’t think it’s brake related. I attached 2 videos of the noise hoping someone can help me out.Thanks.
Jul 17, 2024 at 6:32 PM
