The gear shift module sounds like it is out, but to be sure we should scan the CAN. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
The gear shift module is power directly from the fuse fFYI, here is how to change the gear shift module out in case you need it which should fix the problem. I must tell you there is a TRCM that can go out which might keep the gear shift module light on as well. This is why the CAN scan will help us. I have included both the gear shift module and the TRCM in case a code is stored for it. Check out the images (below). Please let us know what happens.
Oct 1, 2024 at 12:48 PM
