1969 Rolls Royce Silver Shadow starter switch
1969 ROLLS ROYCE SILVER SHADOW
89,000 MILES • V8 • 2WD • AUTOMATIC
DONEGAL
Replaced starter swich with comperable year, but there were extra wires that came from internal from the switch box. Did the exchange, one wire at a time, matching the colors. The car will not start, the solenoid does not engage, nor does the starter turn over. The lights work properly.
May 25, 2010 at 3:46 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
We do not have any info on this wiring problem, but you can work it out, there should be Power all the time, ignition feed acc feed starter feed, with a multi meter you should be able to work out what each switch wire does using the key position as a guide, if you do not feel that you can do this, a mechanic can check this out for you, with the steering lock off, if fitted you will be able to "hot wire " and drive to a work shop.
Mark (mhpautos)
May 25, 2010 at 6:30 PM
