Rollover accident, need fuel shut off switch location
1994 DODGE DAKOTA
184,000 MILES • V6 • 2WD • AUTOMATIC
DHERRING
MEMBER
FOLLOW
Trying to locate fuel shut off switch.
Jun 25, 2019 at 2:04 PM
CERTIFIED EXPERT
Good afternoon,
There is no fuel cutoff switch for the fuel pump. Fords have this switch.
I attached a wiring diagram for you to view.
What is the issue?
Jun 25, 2019 at 3:08 PM
DHERRING
MEMBER
It was in a rollover about a year ago. We are trying to make it usable as a farm truck.
It will run with gasoline poured in the carburetor but then shuts off.
Jun 25, 2019 at 3:53 PM
CERTIFIED EXPERT
Okay, can you hear the fuel pump run when you turn on the key?
Did you remove all the old fuel and replace it with new fuel?
Image (Click to enlarge)
Jun 25, 2019 at 4:03 PM
DHERRING
MEMBER
Did not replace fuel. Added some new and shook it.
Cannot hear fuel pump when key is turned on. I’ll listen again under the car but I didn’t hear it while under the hood.
Jun 25, 2019 at 4:06 PM
CERTIFIED EXPERT
You need to drain all the old fuel out. Adding new does nothing for the contaminated fuel.
I would replace the pump.
Jun 25, 2019 at 4:07 PM
DHERRING
MEMBER
Thanks.
I’ll start with good fuel and listen for the pump and go from there.
