Rodents get into the car and build a nest in the "squirrel cage" fan on the blower motor. I've set traps, used electronic repellers, moth balls and D-con poison cakes, but no joy. I have screen under the cowl on the intake, screen on the driver, passenger and rear vents. I am at the point where I can get the trim off and pull the motor in about 10 minutes and it's escalated to about daily. I thought to make a screen disk with wire rim and fasten that to the top of the "squirrel cage", but these things are pretty sensitive to weight distribution and I don't want to create a wobble. It finally came to me that if I can get a piece of screen over the housing the fan fits into, I can probably solve the problem. Once I take the glove box out I see a piece of duct work running across and covering where I need to get to. That's the best explanation I can offer, but can supply a picture if necessary. I'm almost at the point that I want to call in an air strike.
Jul 15, 2020 at 8:34 PM
