Replacing the rod bearings is a somewhat big job. Since you will need to remove the engine and oil pan to access the bearings, you may as well also install the main bearings in the engine and front and rear seals.
Now here is an issue. Once you access the bearings, you need to make sure the crankshaft is within the manufacturer's specifications. Otherwise, you will likely spin one of the new bearings when it is running. If the crankshaft isn't within the tolerance recommended, the easiest thing is to get a new one and replace all bearings.
Can you tell me what is happening that leads you to believe the rod bearings are bad? If they are, you would likely be better off finding a good used engine simply because once the engine you have is apart, there will be many other considerations.
Let me know. Also, take a look through this link. It describes how to identify engine noises.
https://www.2carpros.com/articles/engine-noises
Sep 5, 2021 at 7:52 PM
