I blew one of the head gaskets from overheating so I decided to take on the task of replacing them. I had no problems until I tried to start the car. When I tried to start it I had no compression in any of the cylinders. After a period of time of diagnosing it I found that it was the rocker arms that was the problem. When I tighten the rocker arm bolts to specs it causes the valves to be open making the loss of compression. I backed the bolts out on all cylinders until I got the car to run and it runs good but the problem is that the rocker arm bolts are just barley tight and this can't be right.
I check to make sure that the rocker arms, push rods and pivot retainer are installed correctly and they are. I am totally baffled! Any ideas would be greatly appreciated.
Dec 9, 2019 at 12:57 PM
