The car listed above is a Gtp SC 3800. I just replaced head gaskets on this car and i used new head bolts but i couldn't find any new rocker arm bolts. I was told by many people that i could reuse the old bolts if i cleaned them with wire brush and apply assembly lube to the threads and torque to 11 ft pounds and they would be fine, so that's what i did, but i'm worried about the bolts backing out later on because when i torqued them they didn't tight up much past hand tight. That seems too loose to me, and i was told not to use thread lock, not even removable thread lock. Any info would be appreciated.
Mar 10, 2021 at 3:40 PM
