Why would it sound like I am riding on all-terrain mud tires?
2002 PONTIAC GRAND PRIX
90,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
SETTERGRENH
  • 80 POSTS
I've wrote you a few times on this same vehicle listed above, why would it sound like I'm riding on all-terrain mud tires on the front, it just started doing this about a week ago with the loud road noise, could it be the wheel bearings because I replaced them a couple years ago with a cheap set. Any help is appreciated!
Nov 2, 2023 at 10:00 AM
Yep, you nailed it, the wheel bearing hub will make this sound when they go out. Here is how to change them out correctly in case you need it. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Nov 2, 2023 at 11:10 AM
SETTERGRENH
  • 80 POSTS
Okay, thank you, I guess that's why my ABS and traction lights are on!
Nov 2, 2023 at 11:39 AM
Yep, that is why :) let me know how it goes.
Nov 2, 2023 at 4:38 PM
SETTERGRENH
  • 80 POSTS
I replaced the front wheel bearings and the ABS and Traction lights are still on, don't I unhook the battery to reset the lights.
Dec 5, 2023 at 6:29 PM
Is the noise gone? Also, the ABS system will reset on its own with no need to clear codes. Let's run the codes to see what is stored.
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Dec 8, 2023 at 9:10 AM
SETTERGRENH
  • 80 POSTS
The noise is gone but the lights are still on!
Dec 11, 2023 at 7:10 PM
Good job, we need to run the ABS codes to see what code it says, also did you try clearing the codes?
Dec 12, 2023 at 11:52 AM
