There is a ringing noise every time I push on the gas pedal going speeds of 50 MPH or higher?
2005 ACURA TSX
105,000 MILES • 4WD • AUTOMATIC
KALAYA
  • 5 POSTS
It stops when I lift my foot off the gas and continues when I push it. It will go away after like 10 mins but it’s a really high pitch sound like the sound after your ears pop. And I hear it from the inside like it’s coming from the radio or something.
Feb 15, 2024 at 8:47 PM
Is the radio on when you hear the noise? It sounds like you have a partially clogged catalytic converter.
This guide can help tell for sure:
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. We need to hear the noise, so we know which direction to go to help you fix the car. It takes time to upload so please be patient.
Feb 16, 2024 at 11:16 AM
KALAYA
  • 5 POSTS
You can’t really hear it well but the air and radio is off. As I go faster than 60 MPH the pitch gets higher and louder.
Feb 18, 2024 at 7:29 PM
Is this a hybrid model? Can you tell where it is coming from front or rear? Thanks for the video.
Feb 19, 2024 at 8:55 AM
KALAYA
  • 5 POSTS
No, not a hybrid model, and it seems to be coming from the front, like almost from the radio. Also both the screens are extremely dim and I don’t know how to fix that.
Feb 19, 2024 at 10:13 AM
Okay, it sounds like the alternator or battery needs to be replaced. This sound can come from the electrical system/alternator if one of the diodes inside the alternator has gone out or if the battery is having a problem and the alternator is overworking causing the noise. I would use a voltameter and switch it to AC voltage, then rev up the engine while the leads are connected to the battery, the voltage should stay at 0, if you get any voltage the alternator is bad.
Here is a guide to help you:
and
Here is how to change the alternator in case you need it or what to see what needs to be done. Check out the images (below). Let us know how it goes.
Feb 19, 2024 at 10:47 AM
KALAYA
  • 5 POSTS
Okay, thank you so much Ken! I will take a look at both my battery and alternator and try and figure out which one it is.
Feb 19, 2024 at 11:21 AM
Sounds good, remember to wear gloves when working with a battery.
Feb 20, 2024 at 10:00 AM
