Right side turn signal flashes fast
2011 HONDA CIVIC
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
SPITFIREBRENT
The right side turn indicators are flashing fast, both front and rear work. I replaced bulbs (OEM) and checked for corrosion in the sockets (contacts are clean and shiny) verified the ground in the socket is making contact with the bulb.
Still flashing fast on the right side. The driver's side is normal speed. The hazards flash normally on both sides.
It seems the new bulbs on the passenger side are brighter than the driver's side.
Mar 9, 2022 at 11:02 AM
WENDY W
  • 86 POSTS
Hello!
It's good that you checked for corrosion inside the light sockets. You may also want to check for corrosion or loose wires at the connector as well. Please see the photos I've attached below.
It's possible there's a bad connection at one of the grounds for the right turn signal (labeled G201 and G701 in the diagrams below).
These repair guides have some helpful tips for diagnosing turn signals that are blinking too fast:
https://www.2carpros.com/articles/turn-signals-blink-rapidly
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Please let us know what you find.
Thanks, Wendy W
Mar 10, 2022 at 7:26 AM
