Right Rear Turn Signal and Brake light (Stop and Turn Lamp) does not light for turn signal or brake. It does work as a Parking Light. It does not work as an Emergency Flasher.
Also, the back-up lamp does not work on the Right side.
The Rear Parking lamp works.
I have checked for the proper bulbs (3057 and 3156) and changed the bulbs and I have changed the Tail Lamp Circuit Board ( http://tinyurl.com/lpwaf2y ).
The front right turn signal lamp flashes at a fast rate (like it would with a burnt out bulb).
All The left side lamps function properly. The license plate lamps and the Center High-Mounted Stoplamps work properly. And all the Front Lamps function properly.
I need my Right Rear turn signal / brake light and backup light to function properly.
How can I fix this problem?
Jul 24, 2014 at 1:12 PM
