I have 76 Dodge W200 and we all know what happens to non ABS vehicle when one slams on the brakes. I have had some close calls with the rear of my vehicle getting away from me. Now, from what I have read is that either my right rear brake's cylinder is leaking a bit OR working properly and the left rear brake is the suspect culprit. With the cylinders being rather inexpensive should I just go ahead and replace both cylinders or can you think of anything else it could be. I have read that it could be the emergency brake but from what I see on this truck the e brake goes to both rear wheels...Under normal braking conditions the brakes work find--slam on the brakes and the right rear tires smoke agains the asphalt and the left rear does not. Any help is appreciated.
Sep 14, 2013 at 4:33 PM
