The right rear axle seal is leaking, the brake shoes are soaked with gear oil, and there seems to be an excessive amount of vertical play at the bearing behind the seal. How much vertical play is acceptable? I plan on changing out the seal but need to know if I should change out the bearing also. The left side barely has any vertical play and the seal shows that it is just starting to leak.
Sep 21, 2017 at 3:26 PM
