Right rear axle seal leaking has vertical bearing play
1998 CHEVROLET SUBURBAN
177,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ERIC888
The right rear axle seal is leaking, the brake shoes are soaked with gear oil, and there seems to be an excessive amount of vertical play at the bearing behind the seal. How much vertical play is acceptable? I plan on changing out the seal but need to know if I should change out the bearing also. The left side barely has any vertical play and the seal shows that it is just starting to leak.
Sep 21, 2017 at 3:26 PM
WRENCHTECH
  • 20,761 POSTS
You definitely have to replace the bearing and possibly the axle also. The bad bearing is what ruined the seal. A new seal will just leak again.
Sep 21, 2017 at 6:10 PM
STEVE W.
  • 15,113 POSTS
Ideally you want zero play but I will let .001or so go as long as the axle is not showing any damage.
Be careful if you need a replacement axle, I would go to a yard for a used one before I trust most of the new ones. As you are going to be changing one, you may want to do both. and if the backer plates are rusty/worn, now would be a good time for those as well.
Sep 21, 2017 at 7:07 PM
