Most times it is the socket itself. Remove bulbs and inspect for corrosion or pushed in connection points.
As far as the wiring schematic, I attached the entire exterior lighting schematic below. I had to cut the pics in half to make them readable. In pic 3, I highlighted the brake light on the right side.
Also, check the ground for that light. It could be corroded or loose. See pic 3 for location.
Take care and God Bless,
Mar 2, 2021 at 7:55 PM
