Intermittent spurts of vibration felt in the steering wheel
2018 CHEVROLET SILVERADO
65,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
RMC625
Feels like wheel hop. Intermittent spurts of vibration felt in the steering wheel lasting 2-3 seconds in duration. Sometimes 3-4 times in 5 minutes, sometimes 30 minutes with nothing. Tires rotated about 6,000 miles ago. show no signs of odd or irregular wear. Speed doesn't matter.
May 2, 2021 at 12:11 PM
Does this happen after hitting a pot hole or joint in a bridge? Or does it happen on flat roads with no bumps?
If there is something in the road that causes this then I suspect you have an issue with the steering stabilizer or linkage.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
If it were me I would lift the front end and shake the tires down by shaking 6 and 12 to check the ball joints and 3 and 9 o'clock to check the tie rods.
Let me know what questions you have or if this is not the issue then made a video will help explain what you are seeing.
Thanks
May 3, 2021 at 6:36 PM
RMC625
FYI, it turned out to be something called "torque converter shudder". A software glitch affecting fluid dispersal, or some such thing. Glitch was corrected, transmission drained and flushed. Now running like a top. Thanks for the help!
May 5, 2021 at 12:11 PM
Sounds great. That makes perfect sense now that we know what it was. Not sure I would have come up with that at this point but that info will surely help others when they have a similar issue.
Please come back to 2CarPros in the future.
May 5, 2021 at 8:15 PM
