I used a caliper piston rewind tool to retract the left rear brake caliper piston. I turned the parking brake off and also sprayed silicon on the boots before starting.
The piston retracted partially back in but then stuck before it was fully retracted. As it is now, the caliper will not fit over the new brake pads and rotor.
Before trying to force it, I thought I'd check.
Sep 11, 2022 at 7:31 AM
