High idle
2019 FORD FIESTA
6,600 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
C K
  • 4 POSTS
I go to start my car and it automatically rev's to 3,500 RPM's and does not idle down. if I put it in gear then it still idles high and sporadically.
Dec 7, 2020 at 12:47 PM
BMDOUBLE
  • 1,139 POSTS
The first place to start would be to get the powertrain control module scanned for continuous and on demand codes. The issue could be anything from a pedal position sensor, throttle position sensor, or a powertrain control module issue.
Dec 7, 2020 at 12:55 PM
C K
  • 4 POSTS
I figured i would have to take it in. how common is this ?
Dec 7, 2020 at 1:04 PM
BMDOUBLE
  • 1,139 POSTS
I personally have only had one that ended up needing a throttle body, but in other parts of the country there could be different issues.
Dec 7, 2020 at 1:21 PM
C K
  • 4 POSTS
Problem solved! I was able to do a hard reset on my PCM by unhooking the neutral from the battery for 30+ minutes. I also allowed the system to set up for a minute before I cranked the engine over.
Dec 9, 2020 at 7:38 AM
BMDOUBLE
  • 1,139 POSTS
Awesome! If it acts up again, do not shut off the vehicle before getting it scanned for codes. For some reason Ford has a large threshold before setting throttle body codes.
Dec 9, 2020 at 9:44 AM
C K
  • 4 POSTS
Thanks for that info! I appreciate your help.
Dec 9, 2020 at 10:01 AM
