Here is the issue: The car listed above Formula model, starts up fine, idles fine (900 rpm's warm). But when driving after it warms up, if I am in neutral coming to a stop or if I push the clutch in to shift gears, it revs up to about 2,000 rpm's and stays there for a bit. It usually triggering a Code 24, but it will slowly start to come back down after a little bit. I also noticed that when below 2,000 rpm's, the vehicle will accelerate slowly with my foot off the gas. I checked again for vacuum leaks, but could not find any, and I have just replaced my EGR tube. My best guess is the throttle position sensor is going bad or poorly adjusted. Am I right or is there something else I should be looking for?
Apr 22, 2018 at 7:11 PM
