If you have the 4.8 inch then I am sure you have the base audio system. This is basically meaning you don't have an amp on the system.
I suspect you may have an issue with the radio though. The reason is, if you look at the wiring diagram the fuse is on the positive side of the system in the PDC. When you reverse the polarity then you are sending the voltage backwards through the system so the radio would get the 12 volts on the ground side up through the radio and then what remains will exit through the fuse and PDC returning to the other cable.
Let's check the fuse in the PDC but if that is okay then unfortunately I suspect the radio is the issue.
The way to confirm this is to check for power at the radio when the battery is hooked up correctly and then making sure the ground is good. If this is the case then the radio is the issue.
Let me know if you have questions. Thanks
Aug 27, 2020 at 3:10 PM
