This model isn't offered in the US. However, I will try my best to help. I believe it is the same as our Toyota Echo.
I need a bit more information. When you say, "spaced off'" do you mean it stopped working? Also, what happened when you applied the brake? For example, was the brake pedal stiff and hard to push?
Also, let me know if you had the computer scanned for diagnostic trouble codes. If you haven't, I recommend it. Here is a quick video showing how it is done:
https://youtu.be/b2IJGfImVvw
I will watch for your reply.
Apr 1, 2022 at 9:05 PM
