Reverse lights not working, the fuse is good?
2006 CHEVROLET SILVERADO
200,000 MILES • 4.3L • 6 CYL • 4WD • MANUAL
B.LUV
My reverse lights aren't working. Where is the reverse light switch located on my truck listed above manual 4x4 wt?
Oct 11, 2022 at 3:10 PM
It sounds like the gear range sensor is not working but to be sure here is the reverse light wiring diagrams so you can see how the system works and which wires to test for power, I did notice the BCM is involved so there is an outside change that is the issue.
Here is how to change out the gear range sensor/reverse light switch in the images below. Let us know what happens and please upload pictures or videos of the problem.
Oct 12, 2022 at 11:41 AM
