Do they stay on if the vehicle is off, and the key is removed? Also, when you shift gears, does the gear indicator indicate the correct gears?
I attached the wiring schematic below for the backup lamps. If you remove fuse 1 in the under-hood fuse box, do the lights and camera turn off?
See pics below.
Feb 17, 2023 at 9:30 PM
