reverse lights.
1988 CHEVROLET TRUCK
25,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
CHEVY__88
  • 102 POSTS
Reverse ligts dont work when shifted into reverse. Changed bulbs and all that and still nothing. Any ideas?
Jan 10, 2016 at 6:25 PM
PACO8224
  • 117 POSTS
Are you getting power to the bulb sockets? Make sure you check your neutral safety switch that is located on the side of the transmission.
Jan 10, 2016 at 6:48 PM
CHEVY__88
  • 102 POSTS
I dont have a way to test it.
Jan 10, 2016 at 7:14 PM
PACO8224
  • 117 POSTS
That will be the first thing I would check, if you can get a hold of a meter or test light
Jan 10, 2016 at 7:21 PM
CHEVY__88
  • 102 POSTS
Would it be a problem if theres no wires on the park/neutral switch which is on the steering column?
Jan 10, 2016 at 7:31 PM
PACO8224
  • 117 POSTS
No the shifter on the steering column moves the safety neutral switch on the trans. That's where the electrical parts for reverse are located not the steering column
Jan 10, 2016 at 7:43 PM
CHEVY__88
  • 102 POSTS
So lets say if i do have power to the bulb sockets, what else would cause it not to work?
Jan 10, 2016 at 7:48 PM
PACO8224
  • 117 POSTS
If you had power to the bulbs and you replaced the bulbs already you would have to check if you getting ground to it
Jan 10, 2016 at 7:56 PM
CHEVY__88
  • 102 POSTS
Well on the driver side they have spilt the green wire and ran another piece to a bolt?
Jan 10, 2016 at 8:21 PM
PACO8224
  • 117 POSTS
Ok let me ask you are sure that there is power going to them sockets?? We cannot continue until that is verified for sure
Jan 10, 2016 at 8:25 PM
CHEVY__88
  • 102 POSTS
Im not sure for the reverse lights, but the other ones yes.
Jan 10, 2016 at 8:29 PM
PACO8224
  • 117 POSTS
Ok we have to check them they run from your safety neutral switch and your other lights don't.
Jan 10, 2016 at 8:37 PM
CHEVY__88
  • 102 POSTS
Ohk, could i just use one of those testers that light up? Dont have a bunch of noney to get a voltmeter
Jan 10, 2016 at 8:39 PM
PACO8224
  • 117 POSTS
Yes the test light is best use for that since we are just checking for power and ground make sure you find a good ground to check the the sockets.
Jan 10, 2016 at 8:42 PM
CHEVY__88
  • 102 POSTS
Ok, thanks alot. I sure will try it. Also have another question, but different subject.
Jan 10, 2016 at 8:47 PM
PACO8224
  • 117 POSTS
Ok what you got
Jan 10, 2016 at 8:59 PM
CHEVY__88
  • 102 POSTS
Well my heater works for a little bit and then all of a sudden it starts to trip out and trys to turn on the fan,defroster,ac and heater and different vents at the same time and only way to make it stop is to pull the fuse. It was working fine until the compressor went out and i just by passed it.
Jan 10, 2016 at 10:53 PM
CHEVY__88
  • 102 POSTS
So im not getting any power to those sockets. Got a test light this morning.
Jan 11, 2016 at 8:34 AM
PACO8224
  • 117 POSTS
Ok check the light green wire coming from the safety neutral switch on the trans. With the test light It should be located on the f slot here is a picture of it to give you a better idea.
Jan 11, 2016 at 9:12 AM
CHEVY__88
  • 102 POSTS
So i can just have the key on and not the whole truck? Or should it matter? And does it need to be in reverse?
Jan 11, 2016 at 9:19 AM
CHEVY__88
  • 102 POSTS
Ok theres two plugs. One on the driver side trans and one closer to the back?
Jan 11, 2016 at 9:36 AM
CHEVY__88
  • 102 POSTS
The top right was the only one that lit up and it was not a green wire
Jan 11, 2016 at 9:45 AM
PACO8224
  • 117 POSTS
Yes it can just be key on engine off, and
Jan 11, 2016 at 9:59 AM
PACO8224
  • 117 POSTS
Yes it can be key on only. And with shifter on reverse.
Jan 11, 2016 at 10:00 AM
PACO8224
  • 117 POSTS
Is it a manual transmission or automatic?
Jan 11, 2016 at 10:06 AM
CHEVY__88
  • 102 POSTS
Auto
Jan 11, 2016 at 10:07 AM
PACO8224
  • 117 POSTS
Ok I think yours is located on your steering column on that year truck let me do some research and I'll get back to you.
Jan 11, 2016 at 10:37 AM
CHEVY__88
  • 102 POSTS
Well if it is then it dont have any wires going to it
Jan 11, 2016 at 10:47 AM
