Reverse light has constant power
1998 DODGE RAM
210,000 MILES • 5.9L • 6 CYL • TURBO • 4WD • AUTOMATIC
J_R_R
I replaced the tail/ reverse lights with the new combination LED lights.
Two nights ago I noticed two of the white (reverse) LED bulbs were lit on the right hand unit. This unit was being replaced under warranty, so I just snipped the wire.
Last night I noticed the left unit was fully lit, so again I snipped the wire for the back up lights.
Today I did some troubleshooting and found there is 9 volts DC constantly feeding to the reverse lights.
The truck is off and in park.
I thought I would try to trouble shoot before I start tearing into the wiring harness.
Any troubleshooting tips would be beneficial.
Thanks for your time and responses in advance.
John
Mar 12, 2017 at 7:49 PM
MHPAUTOS
  • 31,937 POSTS
unplug the reverse light switch on the transmission and see if power stops. if so replace switch, if not look for a rubbed withe that may be powering up the reverse lights.
Mar 13, 2017 at 12:42 AM
