No reverse
1996 NISSAN PATHFINDER
210,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHELLIANN
Have all forward gears no reverse.
Oct 14, 2019 at 6:22 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Have you checked to see if the fluid level is correct?It sounds like you just lost the reverse clutch pack. That will require the removal of the transmission and a complete rebuild. You might also want to see if your local auto wrecking yard might have a used one hopefully with a small warranty. Rebuilding your transmission is roughly $1,000.00 to $2,000.00 depending on your area/type of shop you go to. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 14, 2019 at 12:55 PM
