Revs up without gas input?
2021 BMW M5
12,000 MILES • 1.2L • V8 • TURBO • 2WD • AUTOMATIC
JOSHEDWARDJOHNSON
  • 10 POSTS
Hi. There is a BMW m5 that i got which revs up without gas input. How can i fix that?
Thanks Josh
Feb 17, 2023 at 12:29 AM
Hello Josh,
The first thing we need to do is scan the car for codes. I would do a CAN scan which is easy and you can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Also, can you please check the floormat to see if it is holding the throttle pedal down slightly? You may have a throttle pedal position sensor that has gone out, but I am hoping a code will come back for it, also has this can had any water damage? Here is the throttle pedal and sensor in the images below, if it gets wet it will malfunction. Please run the codes and get back to me.
Feb 17, 2023 at 10:44 AM
DOCHAGERTY
  • 9,603 POSTS
Is the floor mat in the way?
Dec 15, 2023 at 9:22 AM
ASPENADMIN
  • 20 POSTS
No. Floor mat is not affecting the gas.
Dec 15, 2023 at 9:26 AM
STEVE W.
  • 15,113 POSTS
When you say it revs up without input, is that from idle or will it idle and then increase rpm without anything being touched? If it is from idle, I would look for a vacuum leak. It doesn't take much of a leak to bump up the rpms at idle. A quick way to test is to get a can of common carb cleaner or even an unlit propane torch. Then go out with a cold engine, open the hood and start it. Now start spraying or moving the torch around the lines and intake areas. You want to listen for the RPMs to change as you move the additional fuel source around. If you find something then shut it off and visually inspect for a line off, cracked or damaged.
Dec 16, 2023 at 12:26 AM
