As mentioned, the car gets dangerous when the engine gets to the normal temperature.
A° As long as the engine is cold, it runs quite okay.
But,
B° When getting a normal temperature for its use, the engine goes wrong :
It goes up and down, but never stays stable.
when , and it does, happen when running , then if at low speed the engine stops : therefore the car is not drivable : loss of the assisted wheel system
Let me know where to a) check, and b) to change a temperature sensor , if this is the possible reason ...
I count on you to explain to me in :
- simple and clear sentences,
- English is not my mother tong,
- I will then have to translate to a mechanic in French ...
Thank you for your help.
Best,
Didier
But,
Best,
Didier
Jan 10, 2023 at 7:18 AM
