It could be any of the above issues.
Lets start with this. I have a flow chart for testing. I will give you the start of it. Once you do this and let me know the results, I can move you to the relevant next steps.
________________________________
1994 Ford Truck Ranger 2WD L4-140 2.3L SOHC
KE1 - Check For RPM Drop
Vehicle Powertrain Management Computers and Control Systems Testing and Inspection Pinpoint Tests With EEC IV (OBD I-A System) Pinpoint Tests KE - Idle Air Control Control Solenoid KE1 - Check For RPM Drop
KE1 - CHECK FOR RPM DROP
Diagnostic Trouble Code (DTC) 412 indicates that during Engine Running Self-Test, engine rpm could not be controlled within the Self-Test upper limit band.
Possible causes:
- Open or shorted circuit.
- Throttle linkage binding.
- Improper idle airflow set.
- Idle Air Control (IAC) solenoid contamination.
- Items external to Idle Air Control system that could affect engine rpm.
- Damaged IAC solenoid.
- Damaged Powertrain Control Module (PCM).
- Key "OFF".
- Connect engine tachometer.
- Start engine.
- Disconnect IAC harness connector.
- Does rpm drop or stall?
Yes -- Go to KE2. See: Computers and Control Systems > Pinpoint Tests > KE2 - Check For Other DTCs
No -- Go to KE3. See: Computers and Control Systems > Pinpoint Tests > KE3 - Check For Other DTCs
__________________________________________________
Also, here is the test for the tach not working
R: Tachometer Always Indicates Too High or Too Low, No Tach Indication/Tach Indication Erratic
Vehicle Instrument Panel, Gauges and Warning Indicators Instrument Cluster / Carrier Testing and Inspection Pinpoint Tests Electronic Instrument Cluster R: Tachometer Always Indicates Too High or Too Low, No Tach Indication/Tach Indication Erratic
R: TACHOMETER ALWAYS INDICATES TOO HIGH OR TOO LOW, NO TACH INDICATION/TACH INDICATION ERRATIC
R1 CHECK WIRING
^ Make sure engine is not misfiring.
^ Disconnect battery ground cable
^ Remove instrument cluster.
^ Using Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent, measure resistance between connector B Pin 20 and coil.
^ Wiggle connections and wiring near coil to check for intermittent connection.
^ Is the resistance less than 100 ohms?
Yes
REPLACE instrument cluster. RECHECK operation.
No
SERVICE wiring Circuit 11 for open circuit.
Let me know what you find,
Oct 31, 2020 at 11:13 AM
(Merged)
