Retrieve engine codes
2005 HYUNDAI SANTA FE
175,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
HARRIS63010
  • 7 POSTS
Is there a way to retrieve engine codes without a scanner?
Feb 16, 2020 at 9:30 AM
Good morning,
No, you need a code reader to access the ECM for codes. You can have them read for free at a parts store.
What is the exact issue?
Feb 16, 2020 at 9:42 AM
I attached the location of the data link connector and the procedure.
Feb 16, 2020 at 9:45 AM
HARRIS63010
  • 7 POSTS
I live 15 miles from the auto parts store where they could scan it. The problem is the car wont make the trip. Is there anyway to retrieve codes without a scanner. It doesn't have any power. Meaning it seems to be in limp mode.
Feb 16, 2020 at 9:56 AM
Again, no, not without a code reader.
What do you mean by limp mode? No response from the pedal or the transmission is stuck in 1 gear?
https://www.2carpros.com/articles/engine-has-low-power-output
Feb 16, 2020 at 10:13 AM
HARRIS63010
  • 7 POSTS
Meaning that I took it out for a drive this morning got about 5 miles down the road and it starts giving out. The car would barely go. There was a plastic piece in the upper intake manifold on the inside of it where it connects to the throttle body. It was broken when I removed it. So I put the manifold back on after replacing the rear three spark plugs and wires. Now it doesn't want to go hardly at all. Any thoughts would be helpful. Thanks.
Feb 16, 2020 at 10:59 AM
Can you post some pictures of the part that is broken?
Feb 16, 2020 at 11:12 AM
