Took apart front of engine to get access to timing belt (supposedly water pump was changed but couldn't get engine to run, engine would run for at least 1-2 seconds, but would not rev-up, gas pedal straight to the floor.) Anyways removed everything, able to see timing belt all 3 sprocket marks are off, (could be) the top right sprocket marks line up including where the rotor would hit #1 contact point. So I'm assuming I can turn bottom sprocket back to where marks match up and since this only controls the oil pump(?). The top rear sprocket I can probably move clockwise one tooth(?), that is how far that is off. I'm only basing this off of where the rotor is positioned. I hope this is descriptive.
Mar 16, 2021 at 6:45 PM
