Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Kia
Sephia
Drivetrain
Transmission
Computer TCM
Replace/Remove
Resetting the TCM
2001 KIA SEPHIA
200,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ELFMAN
MEMBER
1 POST
FOLLOW
Was told I can reset the computer by jumping 2 terminals after changing the 1-2 shift solenoid. What 2 terminals?
Mar 26, 2020 at 9:33 AM
CERTIFIED EXPERT
Good morning,
there is no resetting the TCM at all. There is reprogramming but that is done with a factory scan tool.
You can remove the negative battery cable for a minute and reinstall. That will make the TCM forget the code for the time being.
If your repair was correct the light will go out. If it is not correct, the light will remain and further diagnostics are required.
Mar 26, 2020 at 9:51 AM
