You have the transmission with the shift paddles behind the steering wheel? This would be the Agitronic transmission which is a fill for life transmission. Mini says you do not change the fluid unless you go into the unit and replace something or rebuild it.
Many people think they got this wrong so I am sure you can find some websites out there that will take you through how to change it but I would suggest sticking to what the manufacturer says to do. They know the vehicle better than others and if they say it is fill for life, that unless there is an issue, I would not mess with it.
Is there a reason you want to change the fluid?
Jan 8, 2020 at 5:37 PM
