I have asked you guys about the difficulty i was having with putting it in 1st gear while at some occasions it is easy. Lubricated ever, changed the oil, still the same, also there was a noise i wasn't sure of turned out when you press the clutch it goes away so i guess the throw out bearing is going out because the noise is down by the transmission only when clutch is depressed. Also the clutch pedal is held for 20-30 seconds the gear is hard to come out of first gear as if the bearing is baked on the clutch. How hard is it to replace the throw out bearing on this one?
May 12, 2020 at 1:59 PM
