Can you tell me how to set the marks when replacing the timing chain?
2021 CHEVROLET TRAILBLAZER
50,000 MILES • 1.3L • 3 CYL • 2WD • AUTOMATIC
AKON54
MEMBER
FOLLOW
Tell me how to set the marks when replacing the timing chain on vehicle listed above with a 1.3 Liter Turbo I-3 L3T Engine.
Sep 15, 2023 at 11:02 PM
CERTIFIED EXPERT
This process requires special tooling. You need them to prevent the camshafts from moving and properly setting them.
If you look below, I attached the directions for installation from my manual. Take a look through them and let me know if you have questions,
See pics below.
Sep 15, 2023 at 11:14 PM
AKON54
MEMBER
Thank you very much! one more question, is any special tool required when installing phase shifters?
Image (Click to enlarge)
Sep 16, 2023 at 12:09 AM
CERTIFIED EXPERT
Yes, they have special tools for everything anymore. LOL As far as the phasers are concerned, I attached the directions below for replacing them. The tools needed are indicated.
Let me know if this helps.
See pics below.
Sep 16, 2023 at 9:33 PM
AKON54
MEMBER
Thank you, is it possible to find out what is the distance of the internal part (in millimeters) on this device?
Sep 16, 2023 at 11:24 PM
CERTIFIED EXPERT
I'm not sure what you need. Are you talking about the clearance between the pistons and valves? If so, that isn't something I have.
Sep 17, 2023 at 1:09 PM
AKON54
MEMBER
no, I need distance inside the tool itself (number 3 in the photo).
