I have the car listed above EX-L with dual zone HVAC. The passenger side only blows cold air when in heat mode. I removed the blend door actuator which was a Dorman part 604-935 147 22220. While it was removed, I could access the arm for the flap, and confirmed when I moved it up, hot air would come out passenger side vents. Also, when I changed the temperature from cold to hot it would move about 45 degrees in a counterclockwise direction (when looking at the arm on actuator). So, it seems to be working, but since I purchased this car used and never used it when it was cold, I'm not sure it ever has worked correctly since I have had it. I reinstalled it in the cold position (when I set air to lowest temp) and when flap is in position to just blow cold air. I can see that I have the actuator pin in the slot of the flap arm when re-installed, but when I test, I see it moving on the flap arm but it's not moving up to close the flap for hot air. So, my question is, is this Dorman actuator the correct part, should it move more than 45 degrees? Or am I installing it incorrectly?
Jan 21, 2025 at 8:20 AM
